^ so how would that work with the sound coming from the ps3/media player/sky hd /tv?
Well you would connect the PS3/Media Player and the Sky HD box (if it is a HD box) to the amp via HDMI and that would carry the video/audio to the TV and obviously the audio would go through the 5.1 speakers connected to it.
You wound also be able just to connect audio to it either by optical tos-link or coax digital and keep the video signal going straight to the tv.
This model doesn't support sound over HDMI, so you have to connect optical/coaxial cables up for sound from each source.
Your TV to amp will be via optical or RCA analogue cables, since freeview isn't 5.1. There may be a difference in quality between RCA and optical, I'm not sure though.
Sky HD can only do 5.1 via optical/coaxial not HDMI so you'll need two connections to your amp for sound and video if you want to use the amp to switch sources.
PS3 can do sound via HDMI or optical and your blu-ray can do sound via HDMI, optical and coaxial.
So your amp would need at least 2 opticals and a coaxial to do 5.1 for PS3, Sky HD and blu-ray. If you're not bothered about HDMI switching and have 3 HDMI connections on your TV, then I'd go for an older Cambridge Audio amp second hand or graded stock (usually only 3 months warranty though) and run everything via optical.
If you want HDMI switching, then maybe an Onkyo 307, Sony H500 in the link above or Yamaha 365 but none do audio over HDMI so you'd have to connect all audio via opticals/coaxials & maybe RCA for TV. For a little bit more you can get this graded Sony STR-DG820 (very highly rated) for £180 and it'll allow sound via HDMI inc. HD sound but it's limited stock and short warranty
http://www.richersounds.com/showclearanceproduct/SONY-STRDG820-BLK/Sony+Strdg820+Blk.html
Personally, I'd pay a bit more and get one that does HD sound for blu-rays(which is only over HDMI so all HD sounds amps do audio via HDMI). I'd get a Sony STR-DH800 for £230ish
http://www.richersounds.com/product/av-receivers/sony/strdh800/sony-strdh800 which is the replacement of the DG820 so a years warranty minimum and brand new. Again HD sound and expandable to 7.1 or bi-amp your front speakers so gives room for growth instead of having to upgrade in a year or 2 or 3. Other alternatives are Onkyo 507, Yamaha 465 or Denon 1610 (reviews don't rate these as high as the Sonys but reviews are a bit of difficult thing to go by all the time). Or there is the new Onkyo 308 which does HD sound and able to pass through 3D TV signals over HDMI, which may be handy if you're thinking of getting a 3D TV, 3D sky or 3D blu-ray.
That Denon AVR 3200 would do the job also if your Sky has a coaxial because I think that amp has only 1 optical from a quick google.
Personally, I'd get an amp that does HD sound, you can connect everything up to it simply and only have one connection going to your TV and with 5yr warranty for about £100 more. Also, if you don't use Richer Sounds' warranty you can get a refund for it a month before or after it expires so you'll get nearly £25 back.
