Audi TT Stronic
Hi Cisco peeps,
Got an 871W (1 x WAN 4 x LAN), trying to set it up so
1) it transmitts two SSID's (1 Main SSID and 1 Guest SSID)
2) The main SSID give access to all internal and the internet and gets its ip from our dhcp server (this is working great !)
3) The Guest gives only access to the internet and gets its IP from dhcp in the 871 (not working properly)
The Guest access has confused the hell out of me. The main SSID acts as an access point so its just a fancy L2 switch really.. But I need the guest one to be able to speak to everything as well despite it being on a different subnet so that I can then create access rules. BTW there is an internal dhcp which dishes out IP's to the guest access no problem.. and I can ping 192.168.1.252 from the guest network but nothing else
Any ideas ? here is what I have so far
Code:
version 12.4
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname Cisco871
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
dot11 ssid Main
vlan 1
authentication open
authentication key-management wpa
mbssid guest-mode
wpa-psk ascii 0 password1
dot11 ssid Main-Guest
vlan 2
authentication open
mbssid guest-mode
wpa-psk ascii 0 password2
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.101.1 192.168.101.10
ip dhcp pool guest
import all
network 192.168.101.0 255.255.255.0
domain-name mydomain.com
default-router 192.168.1.252
archive
log config
hidekeys
bridge irb
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
no ip address
duplex auto
speed auto
bridge-group 1
interface Dot11Radio0
no ip address
encryption vlan 1 mode ciphers tkip
encryption vlan 2 mode ciphers tkip
ssid Main
ssid Main-Guest
mbssid
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.2
description Guest WLAN
encapsulation dot1Q 2
ip address 192.168.101.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Vlan1
no ip address
bridge-group 1
interface Vlan2
no ip address
interface BVI1
ip address 192.168.1.252 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
