Clifford alarm help
Car  Range Rover sport 4.2 S/C
On my other car it has a clifford g4 when you press to lock the car it locks the passenger side but not the drivers side, and when you lock the drivers side with the key you cant unlock it :mad: so you have to go in via the passenger side .
When i press the centrel locking button inside the car 3 or 4times it will lock the drivers side but it never unlocks it :quiet:
Anyone got a idea whats causeing this to happen ?
No its on my other clio 1.4 alize which im selling so i need to fix the problem
sounds like a problem witht the drivers door lock solinoide, may be a loose connection or something, it is just recently its started?
It been like it for awhile now never got round to fixing it , i had the door panel of the other day you can hear it trying to lock
If the deadlocking is jamming on in the drivers door, its probably the linkage out of adjustment.
It could also be electrical, as in , the deadlock is not being switched out during the open signal time.
Look at the plug and connector assembly on the front edge of the drivers door.
See if its tight and make sure there are no signs of water getting in there.
Take the Torx screws out and pull the plug.
clean the contacts (careful 2 of them are live on the car side) and spray with WD 40 before putting it back.
