Climate control heater problem
M90SR
Hi Guys
My heater unit is able to blow out hot and kind of cold air. But you cant switch between them when the engine is running.
For example, say the heating was set to hot and you were driving, even if you turned it down to MINI with AC it would do nothing at all. But if you switch the engine off then set it to cold and then turn the car on it successfully changes to cold but then you cant change it back to hot without repeating the same process.
I have a 2003 dynamique and I have the digital heating unit. Its annoying problem one I have to turn the car off while driving and change then quickly turn it back on again.
Cheers!
