climate control problem.
Car  Clio 172 ph2
as above i have a problem with my climate control in my 172,
The display works as usual just no air coming out!!
ive checked the fuses, none gone!
any ideas???
cheers sam.
looking thru a few threads and im guessing it could be a resistor or transistor?
where is the unit or what ever it is that contains these resistors/transistors
i havent had the car long so havent learnt much or explored!!
cheers guys
probably the heater matrix has gone! they are under the scuttle panel on passenger side! you'll have to replace the unit with the heatsink on. I had same problem a while ago. a new unit is about 100 notes from renault!
