Clio 1.5 dci perfomance problem
  clio 1.5 dci 2004
Okay fellas, so i changed one injector due to car not starting properly. After the change car starts pretty good, idling is good. But my perfomance is low, car won't go more than 1.9k rpm even with flooring the pedal. I had this problem before i replaced the injector, but it usually went away. Black smoke from exhuast while trying to accelerate but car just wont go faster!!!
So my question is: can it be a turbo? also the injector i changed is still not coded into ecu. There s also a little of air in fuel return pipe
