Clio 172 cup gear box code
lancecup
  clio 172 cup
The gear box on my 172 cup makes some horrible noises. Im going to change the oil at the weekend and see if that makes any difference but im not convinced its going to help much.
Im thinking about buying a second hand gearbox and having it rebuilt so i have one ready for when mine goes bang. As i understand it i need a speedo drive box but i cant work out what code these boxes use.
Has anyone had a gearbox rebuilt? is it something any gearbox specialist should be able to do? Is there anyone on here that can do the work or sells reconditioned gearboxes.
lancecup
  clio 172 cup
  Ph1 172 turbo
I’m sure it physically fits but you won’t have a working speedo. As the cup uses a speedo sensor fitted into the 129 gearbox (not compatible in the 130) as it uses the abs for the speedo.
That’s my understanding anyway.
