Clio 172 ph2
Hi all,
I've lurked on this forum for a long while, but yet to post. Need a bit of help with an issue.
Noticed the car is grumbling and runs rough, investigated the issue a bit.
Taken to garage but no fault codes found (besides aircon), so they gave me it back without charge.
I've changed the spark plugs, these haven't been done since at least 2015 so probably overdue.
Noticed plug 4 (LHS) was sooted up. After changing this continues onto the new plug.
I'm guessing this might be an injector, but before I pull the trigger on this am I thinking along the right lines?
I ask because on looking on this board and others, these tend to throw warning lights and/or fault codes.
Beyond that all I can think of is HT leads, or god forbid compression. Have ruled out coil as the other cylinders are fine.
Thanks!
Thanks!
