Clio 172 Windscreen Wipers not working
  Renault Clio 172 Cup
Hi all,
Driving to work this morning in my Clio 172 cup and the front wipers suddenly stopped working. It rained heavily the day before and they were working fine. Cant find much information on this, except test the connections and GND.
Has this happened to anyone else, or does anyone have any info on what the issue could be and how to fix?
Thanks(y)
Brigsy
  T.Turbo
Ive had the wipers go off with uch faults, lights and electric windows usually stopped at the same time.
chazza114
Mine stopped working randomly on the motorway one night, no prior evidence of it happening. Turned out the nuts under the caps holding the wiper arms on had come loose. Tightened them back up and they've been fine since. If it's not that it could be the motors have packed in.
Ah okay, I will check them when I get home
Brigsy
  T.Turbo
Id check power at the connector, will give you an idea whats going on. If its dead and the wiring checks out ok and stalk is good, itll be uch. Its an easy repair though the fella on ebay called diesel repair specialist does a good job and cheap.
