Clio 172 with P0136 and P0300 codes.
Car  Clio 172
Evening guys, got an issue with my car.
As the title says I have both P0136 (o2 sensor circuit malfunction, bank 1 sensor 2) and P0300 (random/multiple cylinder misfire detected) codes showing on my car and I can clear them but both return immediately. It has a slightly rough idle but runs fine other than that.
I have changed the plugs and checked for the misfire by pulling the plugs off the injectors one by one, all of which make the rough idle worse.
Today I have changed the o2 sensor and the problem still persists. It's not a major issue but I don't like the EML being on.
All help and advice is appreciated
I also have this issue too, try changing the coils, if that doesn't work the crank sensor could be bad
This is an old thread I posted mate, turned out it was a dodgy injector, runs sweet as a nut now. Hope this helps you.
