Clio 182 FF
				Hi,
My clio 182 has developed a starting issue. Most mornings when I go to start it, it will start but immediately cuts out (no jolts or funny noises etc) just like if you started it and turned it off yourself. It will always without any doubt start on the 2nd attempt everytime.
The car drives fine, got the normal rough idle but drives as good as ever and smooth regardless of revs / gear / speed. No lights on the dash either.
I have also noticed that the clock on the sat nav screen sometimes shows 6:00 and after 5 minutes or so will switch to the correct time. Also, once the car has started I can press auto on the climate controls (I am able to adjust temp/fan speed and all displays correctly) it takes about 10 seconds to actually kick in and for the fans to come on. Everytime after that I can press off and whenever I select auto they come on instantly! Just plays games when first started.
I have changed CTS genuine and TDC sensor again, genuine with new loom but made no difference. The car has had all belts done , including dephaser (genuine parts) about 2 years ago and is serviced every 3k or 6 months whichever I hit first with elf oil.
I have seen a previous post and someone said they're sensitive to voltage drops at startup regards battery
Hope someone can help
Mike
Mike
