Clio 182 driver side repeater
hopgop1
I'd check you're getting power to the bulb holder with a multimeter, check there's not any corrosion on the contacts etc.
  2012 clio 1.2 tce
If everything else is working it will almost certainly be corrosion inside the bulb holder. A multimeter may not read if there is sufficient corrosion to prevent a good contact with the metal. Just make sure nothing is switched on when you try to clean the contacts,
