Clio 182 2004 no start
Car  Clio 182 cup
Hi Guys, I’ve got an issue with my Clio 182 2004. Trying to start and I’ve got a battery warning light and stop light. Trying to start and the starter motor is turning but no start. Battery is showing 12.6v on the multimeter and I’ve got an earth on the engine and bodywork. Thinking alternator but not sure. Any help would be appreciated. Thanks Matt G
Wont be the alternator causing non start.
If its cranking with no immobiliser light on then you need to check if fuel pump is working. Also is rpm needle moving when cranking as that gives you an indication that the tdc sensor is working
I’ll nip out now and check if the rpm needle is moving when cranking. Strange thing is this happened last week, I got the car recovered to a garage then it started first time. As soon as I drove it home and left it overnight it wouldn’t start again?
Just checked and the rpm needle is not moving when trying to start. Immobiliser light is going off though.
It could be tdc sensor related, need a scanner to see if rpm is registered.
Can you hear the fuel pump prime? It only does it on 2nd cycle of ign turned on
Just went to start it again and it started first time. I can hear the fuel pump prime and I’m getting 15.5v off the battery when it’s running. No idea what’s going on
