clio 2003
I have a puzzle for all, I have a clio 2003 and when I connect the scanner in real time data: all the sensors are OK but only the CKP (crank position sensor) reading is frozen in 198 rpms, I give it start and it does not move (Change the CKP sensor, change the wiring of the ECU to the sensor) the immobilizer is not blocked, the red light blinks and goes off, I open the key and the gas pump is heard, no spark no injection, no new battery, some Experience or someone already through this? Note: no dtc or fault codes
Thanks in advance.
Thanks in advance.
