My car is like 9 years old now, it failed on
• position lamp not working nearside front
And it got an advisory on
• offside front (daytime running light operates dipped beam)
Renault specialists at arnold clark have looked at the car today and can't find why it's happening, and suggested I replace both headlights and control boards, cost of £2400!
I'm hoping someone can link some aftermarket headlights for the 220 trophy that are cheaper than that please? Or suggest a fix that might work? I have until Monday to get it fixed and retested, the car is my daily driver which I need for travelling to work and back.
A bit more info on the fault, the drivers side mud guard was left off the car for around a week while I waited for new rubber rivets to fix it back in, during that time I had to do motorway driving in the rain, I'm convinced the water damaged something becuase the fault started a few days later. When the car is turned off, it looks like it's the side light, it flickers or stays lit, either or, for around ten seconds, then goes off. It flickers the whole time the engine is running too, but it stops flickering when the headlights are turned on. I noticed a plug with a lot of wires up inside that wheel well, could that plug be the cause if it's corroded or something?
