Clio 4 RS monitoring system voltage
  2014 Clio RS
Yesterday on a hot Canberra day (~35 degrees C) my 2014 Clio RS 200 chucked a "Check auto gearbox" error.
It locked in a gear and I was stuck until I turned it off at the traffic lights and restarted it.
I have a little OBD2 HUD and I noticed that the voltages were odd. So today I also put in a cigarette lighter voltage monitor. I thought that perhaps the digitial voltage recorded from the ECU might not be the system voltage. In fact there is a constant 0.2 V offset between them, probably just A to D variation.
My voltages vary from about 11.8 to 15.1. Typically on a cold start they sit from about 13.8 V to 14.2 V and I'm happy. But then they start to jump all over the place. The battery seems to put out about 12.7 V but often I see 12 V or less when driving down the road. The same happens often at idle: the voltage drops steadily from maybe 13.5 V down to 12.1 V.
Such a wide range seems a bit crazy. Especially I don't want to be discharging the battery when idling in traffic! Or when driving down the road. I had a VW bus with a dead alternator and it didn't end well :cool:
And I'm pretty sure that in the colder weather the HUD showed 13.8 V to 14.1 V most of the time.
I've noticed that people often fix the "check auto gearbox" error with a new battery. But perhaps the culprit is really poor voltage control and the new battery just holds out better.
Matt Cup
  Leon Cupra
This seems to be the common first fix before you venture into changing the TCM.
