Clio boot light & interior light?
  Clio MK2 1.2 Dynamic
Just bought a Clio MK2 02 plate and i want to put all xenon bulbs all round it, i have all the head lights and fog lights :)
Was just wondering what size is the; Rear boot light, inside the boot light & interior bulb?
Thanks if anybody gets back to me :)
McGherkin
Macca fan boiiiii
Can't remember the numberplate light offhand, but the interior boot light is a 38mm festoon.
Interior bulb type is different for different light units IIRC (with/without maplight)
Oh, and you'll either need two bulbs or a bridge rectifier if you want to convert the interior light to LED.
Thanks Boosh!
Yeah i thought it was a 38mm festoon bulb :) - Just need to find the number plate bulb size.
So is it possible to change the map light to an LED?
  Clio 1.2 Extreme.
Thanks Boosh!
I found the number plate bulb off amazon i think it was? Best way is to open it up and inspect it yourself!
Dunno why i'm replying you probably ain't even using this anymore!
  Iceberg Clio 172
I just put LEDs in the interior light - the map light works fine but the interior light is on constantly but really dim (when the switch is in the off position) when I switch to map light it goes out. Any ideas why this is? It doesn't do it with normal bulbs.
McGherkin
Macca fan boiiiii
It's normal, the LED needs a lot less power to turn on. I'd just leave it, you could wire a resistor in but you'd loose brightness when it's on.
McGherkin
Macca fan boiiiii
Nah, it's not a problem. It's power that would be going through there anyway, you'd just never notice it if you had a conventional bulb.
