have you looked at the fuses inside the panel on the passenger side door...even tells you what fuses are for what and has spare fuses and a tool to remove them.
Before you buy a new switch, try taking the switch off is there, and using a piece of wire to short across the two terminals which the switch plugs into to see if they work then?
