clio info please
  clio expression '03
Hi everyone time for my first post
I took the plunge and bought an '03 expression 1.2 16v
I now have a few questions that you might be able to answer.
what is the correct oil 10/30 or 10/40
Timing belt change should it be evey 36000 miles ?
The wheels are not standard they're 17" and I was thinking of replacing with the standard renault alloys but there seems to be a lot of variations, the spare is 14" and the alloys on ebay etc.. are 15". which is the correct diameter ?
could someone supply a link to a photo of the wheel or does it matter which clio alloys should be fitted
Also looking for a good scratch remover. Does a T cut type of liquid help blend in the colour?
whereabouts on the engine block is the engine number
is there anything else I should know?
cheers folks
Deso
  1.2 16v
diameter isnt improtane but the standard alloys are 15", they must have 4 stud pattern to fit, the standard ones are 5 spoke and should come with centre caps, change timing belt every 5 years or 75k
  RB 182
Oil - 10/40 or 5/10
Timing belt - don't know
Wheels - 15" (picture)
Scratch - I wouldn't use T-Cut but if you need something similar try Megs ScratchX, but it depends on how bad it is.
10-40 or 5-40 is what you want in the UK.
Timing belt offical under Renault rules ever 72k/5years whatevers sooner I'd never leave it more than 60k and 4 years though.
I'm not sure what the stock authentic wheels are unfortunatly. Clio wheels are all interchangable (V6 excepted) just got to ensure the offset is right.
If your are or ou sign up as a member you can have a read of these thread of interest
Common Clio problems
http://www.cliosport.net/forum/showthread.php?t=108607
Servicing rules/time/whats done etc (Mk 2 phase 2 none RS cars)
http://www.cliosport.net/forum/showthread.php?t=107876
Engine details are down on the front of the engine from memory will check though.
