clio mrk2 ph2 sunroof leak
  1.2 16v Extream, Black
there is a guide on how to sort it i did it and worked a treat just forgot to put the drainage pipe back on properly lol :D
ill try and find the link :D
  Clio sport 182
check all ur drain tubes the also drain into ur scuttle panel so that means checking ur scuttle drain tubes as they could be blocked and back filling up ur sunroof drain tubes ;)
