clock lights really dim
Car  clio 1.2 16v expression
hi i have a 52 reg clio 1.2 16v expression. the display where the clock and temp is really dim and can hardly see it.what do i do to get access to the bulbs? any help would be greatly appreciated thanks
twisty knob down where the headlight adjuster is might be the problem though aint sure if your car has one
There are two bulbs back lighting this display. If the interior illumination switch doesnt help then youll have to replace one or both bulbs. Its a top of dash off job!
is there any step by step or instructions of how to remove the clock to get to the bulbs. thanks for the fast replies
I have the same problem, my can hardly see my display so if there is instructions to get to the bulbs wtc can i have it to please :o
Pay 10 quid members fee and you will be able to see the guide in the guides section. ;) Easy job once you know how.
There is a knob near your headlight adjustment knob; you can adjust how light/dark the display is although not sure if it effects temp/time display.
