brakes sticking?
brakes sticking?
as above...
sounds like your breaks are sticking bud.
this happened to me when there was loads of snow and i hadn't driven for a few days, the breaks seized/iced up.
the 'clunk' noise is the breaks unsticking.
Is it every time you pull off? And I'd check engine mounts - especially is it the dogbone mount that breaks? One of the sexperts will be in shortly to tell you I'm talking s**t.
This happened to mine.
Check the top gearbox mount is done up securely.
Not a lot, however much a driveshaft was + 1/2 hour labour iirc (I had other stuff done at the same time though)Gumby, how much was it to get the driveshaft changed... If you don't mind me asking?
