cobra imola seats help
maynard
  ph2 172 track car
just a quick question about the fitment for these.
im aware you need x-low subframes, side mounts, and obviously the seats.
can someone explain how all this bolts together properly?
maynard
  ph2 172 track car
bump
has anyone got any pics of how this all fits together or knows of anyone that has these seats?
  Renaultsport 220T
Pretty easy when you have all of the mounts etc in front of you.
Will need to have the car up in the air to undo and retighten the bolts through the floor.
The Cobra subframes bolt into the existing mounting points, plus the outside one into the seatbelt mounting point.
The side mounts bolt onto the subframes and then into the seats. The multiple holes allow you to adjust the seating position to suit. If you are keeping the sliders make sure that the bolts that hold them to the subframes are long enough to let the nuts have enough purchase. Mine didn't. I removed the spacers too.
  Clio 172 Cup
I think you also need 'adapter plates' to go between the side mounts from the seats and then to the low subframe that includes the slide runners. I nealy bought the same setup yesterday, the Imola seat is very comfy, sat in the display model at demon tweeks.
maynard
  ph2 172 track car
oh right, the guy never mentioned the 'adapter plates'.
are these specifically needed as im only looking for a fixed position?
  Clio 172 Cup
Ah maybe not needed, I only needed them because I wanted to use the slide rails that come with the subframe, I could imagine that the side mount plates will just bolt directly down onto the subframe although I didn't ask that. Cobra were very helpful when I dropped them a few emails asking questions.
maynard
  ph2 172 track car
oh right cool. yeah i think i did say i wanted them to just be fixed so i presume i wont need any adaption plates. ill ring cobra later to find out for sure.
anyone get any pics of these seats in their clio??
