cold air feed
Car  Mountune Tractor
It is obvious after searching the site that a cold air feed is a must if installing a BMC CDA.
Are there any guides on how to fit or where to buy from? Really dont want to suffer in the summer from heat soak.
if yer going to front lower bumper , take bumper off , remove the acoustic valve or what ever u want to call it in the passenger wing , then run the air feed tube to front
what is the acoustic valve and what does it do?
Is front bumper best place?
well at the min yer car has a feed from the passenger wing , the valve basicaly detects when the revs are at xx point and opens it to let air through , i took mine off and many others will have done the same.
