computer reset
If youve got the origional xp disk then your ok, change the boot sequence in your bios (press delete when you first start up and have a look through everything to see where you can change the boot sequence) so your cd drive is first, save settings and restart, then press any key to boot form disk when prompted.
Go through the setup its pretty straight forward, and do a full format. Simple s**t. make sure youve got your key to hand.
also Make sure you know which drivers your guna need, ie, ones for your motherboard, sound and ones for your gpu etc etc.
