coolant advice please
  Megane 265 Cup
I need some coolant for my 182, what do I need to be asking renault for? Anything specific or will they know exactly what I need? And how many litres do I need? Price?
Also, can I just top the coolant up or does it need drained etc first? It is sitting bang on the min. line at present.
DrR
  VW Golf GTD
It's ment to be changed fully every 4 years I think, no idea on price.
  Megane 265 Cup
Anyone can confirm that, would be much appreciated as I am gonna pick some up in the morning, thanks.
Also, is it normal that the coolant level falls over time? I am not sure if it has ever been changed, wonder if it is low due to time or if I have a leak...
  monaco 172
I thought it was closer to 7 litres?
Unless the stuff in at the moment is the renault stuff then id do a full change as mixing different ones can have funny reactions.
It shouldnt drop in theory as its a sealed system.
  Black Clio GT
people your buying it from should be able to tell you how much you need, how much it is, and you already know which one to get ;-)
imo you should drain, fill with just water to flush it, drain and refill with new coolant...
Takes about 5 litres, but renault state 7 litres, just go for renault type D green engine coolant, at £10 for 5 litres you cant fall off
  Megane 265 Cup
So do you think a leak is possible somewhere? :(
  a thirsty one
full system from dry including heater matrix etc is close to 7 litres but for a coolant change you will only ever need 5 litres, type D coolant from renault or german swedish and french
it could just have been low for a while if you dont think it has ever been changed and yours cars 4+ years you may as well get it all changed, if its newer or has been done in the past just top it up.
