How do I go about doing this and flushing out the system. I was having a look at the Haynes manual earlier and it said that you had to take off the bottom hose of the radiator and undo a draing plug of some sort on the back of the engine.
What I was wondering though is whether or not you have to undo the drain plug on the back of the engine or if simply taking off the bottom hose of the radiator is enough?
Also, to flush the system do you have to remove the thermostat as it says in the haynes or can you just put the garden hose in one of the hoses from the expansion tank until you get clear water flowing from the other hose?
Thanks.
Thanks.
