Coolant literally pouring out...
  Storm Grey 200
I have a leak, it's been there a while but now it's literally pouring out. It looks like it's coming from the seal around the sump. Is that possible?
  Storm Grey 200
I'm not either. That's what I thought maybe the water pump is leaking Down. I will soon find out.
  Ph1 track 172
sounds like somebody didnt renew theyre anti freeze and now have a split in theyre coolant pipe sumwhere,
most probaby coming out of the water pump, so itll trickle down and drip off the sump,
if you have water coming out of your sump, then you should be asking some serious wtf questions.
  Storm Grey 200
on closer inspection i think its the head gasket or a core plug, fun one for the weekend...
Ian
  Focus TDCi
Mine's similar, the coolant needs topping up daily, but it doesn't appear to be leaking. Everyone I've spoken to seems to think it's the head gasket. It's a 99 plate on ~85k.
iimushroomzii
Toilet roll king
  Transit Connect.
Wont be the headgasket if the coolants pissing out the bottom of the block, Unless the headgasket is no going from being run low on coolant.
  Storm Grey 200
Nope, it was fine, but i guess i'll find out what the problem is when i get to fix it. fun fun.
