Coolant question
  clio sport 172
Can i put this coolant (it goes up to -37) and it has these specs:
AUDI/VW/ŠKODA/SEAT-TL 774 C
BMW N 600 69.0
MB Blatt 325.0
MAN/STEYR-MAN 324
MTU-MTL 5048
OPEL/GM B 040 0240, QL 130 100
PORSCHE-TL 774 C
SAAB-6901 599
VOLVO-128 6083
SCANIA-TB 1451
KHD H-LV 0161 0188
ASTM D 1122 ASTM D 1287 ASTM D 3321
  Clio16v/225 Trophy
If its Glycol based then yes it will be fine but it needs mixing still to protect to around -23 degrees... thats what "type-d" means afterall, not the colour or the fact the pre-mix from Renault has this written on the label.
  clio sport 172
Yes, it's based on mono-ethyl-glycol (MEG) + additives to prevent corosion on aluminium...and mixed it protects to -37 degrees. Is it ok to use it, because now i have some red (VAG) coolant.
  Clio16v/225 Trophy
If you mix it more it'll be weaker and so protect to whatever you need it to... Hydrometers are cheap these days and very easy to use ;)
I can't see why it wouldn't be okay to use as it has corrosion inhibitors. Its just a tad strong at -37 degrees for this climate.
