coolant temp sensor location
Breamy
Think the sensor is playing up. Where abouts is it located? Tried to look but couldnt see it
  Clio 182 Fiat Coupe
You don't need to remove the airbox, there's enough room to change it as it is.
Took me 10 mins tops to remove and fit a new one.
  Clio 220 Trophy
Just did mine today, easy job 21mm spanner or ajustable..... Take off the air box and look for it on the thermostat housing. It has a black plug which inserts in to it! Be quick in changing as you will loose coolant fast! Pars is £24 from renault.
