Standard FF wheels are ET48.5/47.5 iirc, cup turinis are ET37. I've got superturismos on mine which are ET37 and i've got no problems don't rub etc.What is the offset for a 172FF and was is the effect of fitting Turini's??
No rubbing now i've got rid of my coilovers and fitted -30mm spingsStandard FF wheels are ET48.5/47.5 iirc, cup turinis are ET37. I've got superturismos on mine which are ET37 and i've got no problems don't rub etc.What is the offset for a 172FF and was is the effect of fitting Turini's??
You should have asked the question before ordering... If you're not going to lower your car then you have no problem i suppose but the wheel might sit in the arch a bit??
i had the 2118's in et38 with 195/50 on my 182 lowered on coilovers and there wasnt any rubbing, iv got the et43 version now with 205/50 and there isnt any rubbing so you should be fine on standard suspension, even lowered 20mm (im guessing on eibach pro's?) u should be fine!
