Cost of Renault Sport Backbox?
  Black 172 ph2
Guys,
Any ideas on how much a standard Renault Clio Sport 172 backbox from Renault is?
Chris
  Black 172 ph2
Yeah will do but they wanted my chassis number which i didnt have to hand as im at work.
  Black 172 ph2
Cheers Stu.
I have heard that the K-Tec stealth is not as good as the Yozza, but the Yozza is £429!!!
  A Flamin' Red one
It's a CB1N that's the only code they'll need!
Is that a generic code for a 172 back box then? I think mine has started blowing and at the moment with needing new front discs and pads I can't afford a K-Tec Stealth.
Can you confiirm that a back box can be removed and a new one fitted and that it doesnt all have to be replaced as one unit, as is mentioned by msa197 a few posts up? It certainly seems a bit OTT...
  Megane 225
That's part of the VIN that they need to identify a PH2 172 on the dialogys part list. Not the part number of the back box. The original exhaust is all 1 piece, but for replacement they supply the backbox and centre section separately. If they didn't u'd have to drop the rear axle out to fit! Make sure they sell you a clamp for joining to the centre section!
I'll post the part numbers up when I get home tonight!
  Lionel Richie
here's the part numbers/prices (this is for the phs2 172)
centre section 8200332139 £148.21+vat
back box 6000073740 £103.38+vat
clamp 7703083397 £19.78+vat
total inc vat £318.86
  Megane 225
Yes, they are all separate part numbers! So if ur centre sections fine u only need the back box and clamp!
  A Flamin' Red one
I only ask because I've read stories of people going into dealerships and being told they can't have one thing without the other. Like, a 182 splitter without the 182!
  Black 172 ph2
In two minds now whether to go for a Yozzasport stealth exhuast at that cost! Might go pay a visit on Friday and see how they sound. Do you know how much they are fitted?
  RB 182 & Lotus Evora
Fitting you can do your self, otherwise an hours labour max? Id get the aftermarket system as the standard one rusts and drops off a couple of years later. Getting yozza/ktec is a long term investment :p Dont rule out GDI too...i have there stealth system and its by far the most fav sound ive heard in a clio. NOt being biased when i say that as im the first person to put my car down for something wrong.
