Couple of problems with the 1.2
  MK2PH2
I was doing 60mph in 5th gear but the engine was racing quite badly and it felt like there should be another gear to go into. After a few minutes of driving at 60 the fans got really hot. (The heating wasn't on). I know the engine gets hot but surely not this quickly?
Also i have recently fit new wheels and when i am driving straight the steering wheel isn't straight if that makes sense?
If you have had these problems before or you know why they are happening i would appreciate the advice. Thanks
  MK2PH2
Not 17"s then so shouldnt put more strain on the gearbox...
Did the engine temp dial go up above the normal?
Erm not sure i diddn't check for some reason :S
Probably get the wheels checked for balance, maybe the engines not racing , its the car shaking due to the wheels being off balance.
Never really thought of that i'll get it checked out thanks
  Fabia VRS Special Ed
Get the balancing & tracking checked ;)
Normally about £30 for the tracking and about a fiver per wheel for balancing.
