creaking from the front end
  1.2 16v
Ive got a slight creaking when i move my steering wheel only slightly just wondering if the Top Strut Knocking fix will sort this? Also now theres a slightly louder noise comming from the front end when driving along? thanks
rctempire
Could be various things, like if your moving the steering wheel, i could be the Track Rod End for example.
Is there anyway you can jack up the car put it on axle stands and shake the wheels?
  Lots of Alfas
I doubt the strut top mount fix will do anything. It could be top suspension mount bearings, steering rack, steering column, the list goes on, need to find out where its coming from.
  Ph1
Had a creeking noise on mine a year back, just oiled the anti-roll bar bushes and all was well.
Might be worth a go assuming 1.2's have AR bushes
  Renault Clio Mk2 PH2 DCI
Ive got the same problem! Only when i turn right get a loud knocking noise but only when the car is moving slowly!
went to the garage today gave me a list of things too check soo to save time and hassle there doing it!!
  ph1 172
i had a creaking noise coming from the front drivers side. it happened when turning the steering wheel left and right. and also when going over speed bumps. i had my bottom ball joint replaced for £115 and the problem has gone.
