Creaking solid top mounts?
RDH
Getting a clicking/creaking at slow speeds and when turning. Top mounts?
Dannyeff
  Clio 182 trophy
yes mines just started doing this.. more than likely seezed. is it pms you have?
  • Like
Reactions: RDH
James363
  Clio 172 Cup
You could try removing the bottom damper bolts and wiggling the damper to see if that is the problem. If they are seized/sticky it should creak or not move when you do this. Fortunately, PMS do sell the replacement bearings.
  • Like
Reactions: RDH
RDH
Yup its PMS top mounts that I have. Sounds like its time to order some new bearings.
