When on full lock going up the drive way i get a horrible creeking noise on the front rhs, and also sounds like something is loose now and again whilst driving in a straight line? Anything on the suspension side i should check out?
yeah will get it jacked up at weekend, and have a play by moving the strut around. It's not a knocking noise just a light noise now and again and more of a heavy noise on full locking whilst going up a kurb for instance. It's fine on full lock on smooth roads. Are they much top mounts?
if it is your top mounts i doubt youl need new ones mate.
Its a design fault and the creeking can more often than not be cured but using a speacial sized washer or grinding part of the turret (Renault do this to cure the problem as they are aware its a design fault). wont do the car any harm so just ignore it or you could pay to get it sorted.
i wouldnt get them from euro carparts there not for the rs, been there done that. lol both my rs have creaked, apparently duck oil is supposed to stop it.
Ok cheers pal, i will have a gander this weekend. Can you tell by jacking the car up and seeing the problem? Just so i know what to look out for. Cheers Bud.
They have like a bearing inside underneath the washer. The creacking is caused by moisture but don't use just wd40 or else it will sieze, oil it afterwards.
