Cruise not working
  BG 182 FF
Push the switch in, lights up green on dash and says SET......
But doesn't do anything after that regardless of what i push.
Any ideas people?
Rob
jenic
I'd say a wiring fault between the airbag ring and the buttons somewhere. Or maybe a faulty brake or clutch switch, although I'm not sure if it would light up the dash if this was the case, someone else would have to confirm.
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Most likely cause is a clockring fault but really, a session on CLIP to see what signals are being sent when you actuate various parts of the system will pin point your fault.
  BG 182 FF
If i push the down button on the dash panel the orange symbol appears but the switch pings back to neutral position and doesnt hold? If i push up the green symbol appears and the switch holds fine.
I dont know if this is normal or not as its the first 182 ive had.
danward
  M135i
My cruise switch kept on pinging back off whenever I tried to use it - I bought a new switch, 2 min job to it, now it works fine.
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
!!!!!!!! STOP!!!!!!!!!
Do not buy a new switch as they can be fixed. If you've not already done so pay to becime a member then check out the guides section.
Mick
  BG 182 FF
Thanks Mick but i've already taken it apart and fixed the rocker part but still doesn't work.
The green/amber light now stays on the dash but doesn't engage cruise.
We have Bosch KTS at work so will plug it in a see what the pedal switches are doing.
Mick
Do you know off hand what this guide is called exactly?
My cruise and speed limiter switch just flicks back to neutral when I let go sometimes. Sometimes it's fine.
  BG 182 FF
Right, checked live data and both clutch and brake pedals are working fine.
Cruise control is active in the body configuration.
Still doesnt work.
Only thing left??? steering wheel buttons?
  RB clio 182
Its most likely to be the brake light switch. I had the exact same problem. It may say that the brake light switch is working fine BUT if it is too sensitive the cruise doesn't work, also if its not sensitive enough it wont work. I bought a brand new switch and adjusted it so the brake lights came on just as I touched the pedal. The cruise control still didnt work. so I made the switch less sensitive and it worked.
If you dont know already, the switch has a piston in it which you can adjust.
See this guide - http://www.cliosport.net/forum/showthread.php?307978-Quick-guide-on-how-to-alter-brake-pedal-switch
