Crunchin in reverse
  Skoda Fabia vRS
my car is crunchin in reverse badly, its not the usual Clio crunch bcos even if i select first, first, it still does it and its worse than that
it started to do it a few weeks ago and im pretty sure my clutch is on its very last legs, however i had the gear box oil changed and everythin was fine, however its now come back
has anyone ever used any additives for the gearbox that were any good, i can order the Slick 50 one from work afaik or i could get Molyslip/Wynns from Halfords
all i need is a solution for about 3 weeks, cos the GTT will be ready by then, but i dont wanna drive it like this really as i hate choosing reverse as it crunches really loud
could it be somethin else thats worn that i could replace cheaply ?.......ive been lookin in my Haynes and it says it could be a worn/damaged/incorrectly adjusted gear linkage, is this somethin i could have done/replaced reasonably cheaply
The clutch is probably dragging..not freeing and still rotating. If it happens in forward gears could be synchros going or linkages needing lubrication, you can get spray on grease which is quite good.
-Rob
