Cup drivers windows rattle
  Suzuki SV1000S
Have had my cup at the garage all week for the usual bits and peices.
The drivers windows rattle is actuallt the electric motor, it is the auto switch which causes the windows to rattle because when you move the window half way down the auto switch kicks in but the motor is still trying to move the window down (according to renault)
Also make sure you get the rear brake valve limiter thing checked because they told me that this problem is infact dangerous as the rear brakes arent doing half as much work as they should be (all you guys who think the brakes are sh*t this is prob. why)
The front suspension noise is because of the mounts but I think most of you know about this one already.
The other thing is the clutch when changing from first to second, only a few of us had this, apparently it is because the clutch is set too high. Apparently this will wear in after time.
I also had issues with starting the car, but they havent told me anything about that yet, guess I will find out tomorrow.
All this had to be done and my car has only done 3500miles. But wanted to get all the probs out of the way first before fitting quickshift kit etc at the weekend
