turn the cams so they're putting tension on the cover, then walk away for a few minutes
you have removed the pullies haven't you?
fooking hit it!
Can you get a wallpaper scraper in the gap you've made? If so, knock one in with a hammer?!
i have old gasket scrapers i knock in as wedges, it's not uncommon for them to be fairly well stuck down
Can you get a wallpaper scraper in the gap you've made? If so, knock one in with a hammer.
No worries, glad you got it sorted.
It's difficult to tell, they're worse than mine.
Are you putting brand new cams in or just the old ones back in?
Was it previously all running fine?
nothing to worry about, just tidy up the deep ones, i've seen quite a few like that
the cams are steel and the head casing is ali, the cams aren't going to wear!
the car on standard cams at the moment Marten? Believe C&B are supposed to get good. Similar to Schrick.
Cheers for the info Fred a huge stone just fell from my heart.
Yes the car is at stock cams for the moment. It was due for belts so it would have been stupid not to do the cams at the same time. Planing to keep this car like forever and cams were on the to do list just not at this moment. But hey I think Ill be pleased
