damaged V6 pic
Ad
  MK2 FRS
must be touch and go....
easy repair if they do write it off.
  K20 EG Hatch
that isn't at wolverhampton is it?
I heard a guy in renault wolverhampton the other day talkin about his vee gettin arse ended and he is fixing it himself.
Lee
  BMW M2C
Easy, but very expensive. They'll have to replace the entire left rear wing bit as that wraps round to the back.
Lee
  BMW M2C
FlansS14 said:
10k car with 3-4k damage...
Why will the write it off..... !!
At dealer prices that's a lot more then 3-4k. I have a friend who had a rear bump in a V and all that was visible was a crack in the bumper, and the back box was dented and pushed forward. It looked like nothing but the cost was massive.
Replacing those side pods which are bonded to the body won't be cheap, his was a lot more than that and they didn't even need touching.
Ad
  MK2 FRS
A good fibreglass sepcialist/coachbuilders would be able to rebuild a crack wing, if you had the bits...... or you could get one off another damaged car....
at a push, id go for that no being a write off.
  172 Cup
Nah that's defo not Wolverhampton. Does look a lot like Sutton Park Renault though.
  K20 EG Hatch
look at my first 182. Didn't look that bad but it had £7200 worth of damage. It was only body damage too!
Lee
  BMW M2C
Sounds about right to me having heard how much it came to with a lot less damage than that!
  80MPG BEEZA
i saw one in a spray shop being repaired by them but sent by renault and it was having both sides replaces and all the bk end he told me just the cost of one side piece is over 1k thats without fitting flushing and spraying
  v6 mk2
someones had fun!!! did they forget it was rear wheel drive!!!
as for writing it off they probably will, to give an idea the front wings cost over 2 grand!! i would guess a rear quarter would be similar in price!!
There a definate write off I'd say the V6 panels as people have said earier are realy expensive.
Another forum members V6 of here was written off after the side panel was damaged and that was a brand new Mk1 V6 (that was when the Mk1 was the new one).
lmao @ £1k per panel
Replica panels will do, although they may not fit as they should straight away you can make them fit and look exactly the same.
J
jamesy
at that price id never want to take it out the garage for fear of being hit:eek:
