dci Glow Plug Light always on
  "Navy" N17 TWO
My lady-friend's dci65 Clio is giving problems
The glow plug light is always on, can be switched off when hooked up to a diagnostic computer but comes back on again after a few days
No faults are found on the diagnostics :S
Any way of getting it off/back to "normal"?
What can I check?
Trev
  "Navy" N17 TWO
Also the injector light comes on too - and stays on with the glow-plug light as above :rolleyes:
The car seems to be a bit "chuggy" sometimes and occasionally when pulling off it can be a bit more responsive than normal
  Laguna sport tourer
try checking the coolant temperature sensor as this tells the engine how much pre/post heating is required
  "Navy" N17 TWO
No it's a bugger to start from cold - sometimes gives out a wee puff of smoke when you get it started :S
When you're lucky enough to have the light go out - it starts & runs 100%
She wants to try & resolve it before the winter sets in
  Laguna sport tourer
i would go with checking the coolant temperature sensor also check glowplugs for voltage,fuse,relay etc
  dCi 65 + C2 (<Sold)
Lol just posted an identical topic! My dad's having this trouble. Had the glow plugs changed, no luck, phoned Renault they said it's the relay, £50 later and still it stays on. Had the engine management thing reset and it works now, but apparently it comes on after a couple of weeks and goes back to being hard as hell to start.
  "Navy" N17 TWO
Now Dad's car is doing this! :banghead:
Fault reader yesterday said it was an "intermitent Camshaft Sensor fault" - they put a new Camshaft sensor in yesterday and everything was hunky dory.....until this morning on his way home from work.
The glowplug light is on again and won't go out :dapprove:
  "Navy" N17 TWO
I don't think he has actually but I'll ask when I see him later.
Just back from mechanics with it and got the fault code cleared - 271 this time.
"Injector command circuit - cylinder 4"
There's over 138k miles on this little beast!
  "Navy" N17 TWO
Just an update - glow plug was changed a while back.
The car has been fine "so-far" :) apart from being trouble-some to start at times
