len_beach said:The reason it is so difficult is because the manifold studs do not have captive nuts on the manifold, they are normal nuts so it is a 2 man job. 1 Person needs to hang over the engine and twist their wrist to hold a spanner onto the bolts which only have limited head showing anyway.
Furthermore, the manifold to cat joint is right above the back of the subframe so access is limited at the absolute best.
My advice would be to use an open ended 10mm spanner on the bolts down the back of the engine as the flats of the spanner will sit better on the head although it will be more difficult to hold.
Whoever is underneath may find it easier to split the centre pipe 1st so the cat hangs slightly allowing access over the top.
I would also suggest having a range of rachet sizes, extensions and socket sizes as access is so limited.
It's a challenge but worth it in the end.
