Decat - what's needed to fit?
  172
Hi just received my decat, what's needed to fit it as i might give it a go my self?
EG gaskets etc.
cheers.
  Iceburg 172FF
you will probably need a manifold to cat fitting kit, which includes the gasket for the front and a seperate rear gasket, cost about 15 quid in total from renault
  Clio 172
Unless you have access to a ramp and a trusty friend to hand I'd pay the £30 or whatever and get an exhaust place to fit it - JD
Da
  Less
I'm needing this also, fitting it isn't a problem as I did my exhaust but I'll need the fitting kit right?
  Clio 172
yeh, Silicon or firegum type stuff on the meeting faces will be fine, didn't even put the gasket on one end as it was mangled and I didn't have a new one.
  172
cool, cheers.
Just been out and had a quick look and crap! How the heck are you supposed to get to the manifold to cat bolts with a socket/spanner? Theres no room and it's tucked in above the subframe!
The other bolts look easy but they looked corroded!
  titanic killer
You need one person to go up with the ramp and reach over the engine from to get a spanner on the bolts so the person underneath can undo them defo a 2 man job thou
use high temp silicon on the meeting faces dont use exhaust paste as its s**t
  172
It didn't look like a spanner could git in from the top either, looks bad and then it started to rain lol.
Is universal Blue ok for the joining faces?
  340i
haha... you need the hands of a 5yr old and arms of a basket ball player to get the bolts!
Any kind of silicone is fine mate as soon the exhaust gets hot it will seal up
Sib
  Clio 172 (Silver)
Bayliss got my 172 cat off but it was a right b**ch, you can get the spanner on one of the nuts from under the car - we just used leverage for the other.
Paste also did the trick
