Clart ClioSport Club Member Nov 23, 2005 #1 Is there a way to change default gateways on network machines without logging on as administrator and changing the network settings?
L Lee Car BMW M2C Nov 23, 2005 #2 If you want to do it on all the machines you have and run DHCP, set that to assign it to them.
FiDoDiDo Car RB 182 Nov 23, 2005 #3 To change a network protocal's settings you will need to be an administrator.
FiDoDiDo Car RB 182 Nov 23, 2005 #5 Clart said: i found a way using the command netsh Click to expand... Share the wealth then
