Clio 182 Running Issues
Car  Clio 182
Really hoping someone can help me, I have been in contact with Renault specialists local to me but they are booked up until October.
Little back story, I had a poor running car (hesitation and felt like it was cutting out) but I changed leads, plugs and coil pack and that seemed to help for about a month or two but now I have a new issue where it feels like a misfire. The symptoms are most noticeable around 2-3k rpm and the revs seem to drop briefly and return. Under full load it seems ok? Or it could just be less noticeable.
I have since changed the map sensor and checked all the leads again, just incase one was caught when I put the manifold back on.
The exhaust does seem to have a bit of a rattle, and maybe a small leak as the exhaust fumes are quite strong at idle.
Has anyone got any ideas on what this could be? It’s my daily car so I am a bit stuffed without it but it’s scary to drive at the moment.
Injectors can cause a misfire, ones Iv had go the misfire is there all the time so was easier to diagnose by disconnecting one at a time and seeing if engine changed. If no change then that was the culprit.
Maybe a bit harder for you if it isnt there all the time.
Other way to check them is with a multimeter and measure resistance
I did previously change one injector as it was leaking. Might be worth me changing the others. Is it safe to run the engine with the injector disconnected?
