Only 90 miles - 1.5 hours.
Can make a day of it as he will drop you at the Clarke's village shopping place.
Up to you though, can take the risk of a local garage and doing it wrong. Then be on here complaining that your car is broken because the garage didn't do it right. Then you will probably end up going to Dan to have it put right. Depends if you want to make
2 trips to get it sorted or get it done once, and properly!
Someone else from pymouth had his belts changed by a local garage, they messed it up and bent valves he was without a car for a while. Even when they did it right, the timing was wrong. Was taken to Dan and he fixed it all.
