Dephaser Pulley?
  Westy. MX5
To me this looks like an inlet pulley stuck on the end off the camshaft, except the centre is made of some kind of plastic. Is there some sort of mechanism or clutch inside that varies the VVT. Or maybe I'm looking at the wrong pulley.
  Lionel Richie
dephaser on the right
  Westy. MX5
Yep, so why is it different to the exhaust pulley construction and why do some people have more problems with this pulley than the exhaust one.
  Lionel Richie
the dephaser pulley is the main part of the VVT system, its full of oil and works via a 12v switch that allows oil to flow into the pulley (this is in simple terms BTW)
when oil flows in, the pulley is advanced (advancing the timing)
  ITB'd MK1
it's basically got a spring inside that makes it return to a retarded position when the soledoin shuts and cuts off the oil pressure, the spring loosens/breaks/weakens and the pulley slops about a little
  Clio 172mk2
when it fails they become loud and rattle. engine sounds bit like a diesel at times.
If it needs replacing , you have to take all cam belt aux belt off, so as yer paying for all that to come off 4-5 hours labour if i remember correctly, its recomended you replace both belts / kits.
  Westy. MX5
I'm guessing that using the correct oil helps in preserving the pulley and preventing dirt blocking the mechanism.
