Bought a 15 litre DI vessel with MB115 resin and a new Nilfisk E 140.3-9 pressure washer to replace a ruptured Nilfisk C110 which I am going to try get replaced. I have always wanted to do this but never had the cash and having bought the Megane and found washing satin black wheels is the most difficult thing EVER due to spotting (even with C5 applied)... I decided I had to have a DI vessel. Sold a kidney and I was then the proud owner of a DI vessel.
So I got it hooked up to the mains which was reading 305+ (370 the other day) and ran it through, filled 2 large buckets with it and then hooked it up to the pressure washer. Quick water test showed 2ppm Initially (straight after running the water through it before filling buckets) which I was happy with. I thought it had some issues feeding the new Nilfisk but this seemed to sort itself out after a couple of mins and during the final rinse I had no issues. Then I decided to test the water that was left in the Nilfisk at the end of the wash and much to my annoyance it was showing 90ppm.
Decided to drag the vessel round back and see if it just needed water running through it, or perhaps lower the rate of flow through the vessel, but the tests showed 90ppm+ consistently. I was really annoyed, then it dawned on me that I had attached the water hoze on the outlet side of the vessel. Swapped this round and got consistent readings of 2ppm over a continuous 2 minute full flow run. If it stays at 2ppm for the next 12 months I will be thrilled, I hope it goes to 0ppm with the next use.
I think the water feels smoother now (no joke) and there were less suds than normal. Amazingly there is no streaking on the windows atall after drying as usually I would need to run round with AF Crystal quickly to clean the windows. Time will tell if there is any marks left from the sills running
Before and after
9m hoze is a god send but the thing leaks at the inlet just like the reviews said it would.
Hope it looks as shiney on your screen as it does mine.
Before and after
