Ive got valver dials in my RT and they work fine, they also look a bit more *sleek* and different to ya usual ones. The speedo is fine but the rev counter is a bit off. If you wanna do it properly get a rev counter dial from your RT and replace the 16v one, as they are slighly different. I hit my rev limiter earlier today and on the rev counter it showed 6 and a half k, whearas its 7k on the RT isnt it? Anyway the valver rev counter goes up to 8k, the RT is only 7k, so the spacing is different...
Havent got the 3 oil dials working and dont really want them fitted, for a start two of them wont work as I havent got the senders and dont see any point as its just a 1.4 8v car! As for the oil level that shows just before you start up the car you might as well check it properly! They might look pretty good thou but for me its important minidisc space!
As for the external temp sensor bit that you get Ive got the temp sensor Im just figuring out how to wire it up, and if it needs the two lightbulbs that go behind it??!
Anyway, enough babbling, hope that helps..
